My DXF's that are created when checking in assemblies are not "clean". They have bend lines/hatch lines. I need these to come across as No Hidden Lines Type. Is there a way to change this setting?
You need to use a different config.pro on your worker machines that have all of those lines turned off.
display_axes no
display_coord_sys no
display_planes no
display_points no
Andy,
Our Config has that called out. Attached is an example of a simple laser cut strip and a snap of the config details.
Have you tried manually opening the drawings directly on those machines that create the DXFs to verify they are correct?
