Data Format!
jżołądź
Data Format!
Hallo!
WindChill create in Creo part parameter named PTC_WM_MODIFIED_ON. It show date of the last modification.
Default format is: %dd-%Mmm-%yy [expl. 15-Jan-15].
How can I change format to: %mm/%dd/%yy [expl. 15/01/15]
Please Help!
TomU
(To:jżołądź)
Use the hidden config.pro option "date_type_parameter_format" in Creo.
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS49539 for more information.
Thanks a lot!
Can I do this the same with PTC_WM_CREATED_BY and PTC_WM_MODIFIED_BY.
I want on my drawings only initials of person.
TomU
(To:jżołądź)
No, not really.  You can configure these two values to either display the email address or the username.  To extract just the initials, you would need to manually parse the text string and then assign the value to a new parameter in Creo.  Something like this (all on one line):
INITIALS = EXTRACT(PTC_WM_MODIFIED_BY,1,1)+EXTRACT(PTC_WM_MODIFIED_BY,(SEARCH(PTC_WM_MODIFIED_BY," ")+1),1)
Take a look at these pages for more info:
http://communities.ptc.com/thread/51654
http://communities.ptc.com/ideas/3857
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS176501
Thanks, I have setted relations as I wanted to.
But is the way to add all new relations to old parts and assemblies I have in WindChill?
