I want to know is there any solution for how to delete an article which has been promoted but then it got rejected, and for some reason I want to delete that article, but when I try to delete it gives an error that this article is related to a promotion, but the promotion is rejected. So how do I delete the article now.
Windchill 10.1
Thank you
Regards
Sumeet
Delete the promotion request first, then delete the document.
