Deletion of attribute
rkayasth
Friends,
Steps:
1. Create attribute weight
2. Assign to Part type
3. DO NOT create any data
4. Delete the attribute "weight"
It throws an error, saying "its in use by 8 layouts".
Question: what is the way to delete it from the layouts?
Windchill 10.1 M040.
Ravin Kayasth
hello
in the type manager , on your part type, open each layouts and remove the IBA,
you will be then able to delete it
regards
