Dimension Layer Missing in Windchill
pramkumar
I can update my drawing with the exact dimesions, but when i see the representation of the same in windchill, its not showing some dimension layers/some incorrect dimensions in it.
Can anyone help me to resolve this.
Is a new representation being created?
Did the same dimension show up on previous iterations?
Has the recipe file been changed?
Is the dimension on a unique layer?
Yes! New representation has created
No, previous iterations also has same problem, i want the dimension to be as L±1.5, in some iterations this dimesions is missing, and in some iterations it is coming as L±0.5
No.
Thie affected Dimension is a unique layer under one generic part drawing, the remaining dimensions are in different layer under .drw model
Can you post the drawing and model files? Also might want to look at the recipe file. I don't remember off-hand what options are there. Also, what version and package are you running? (9.1 PDMLink?)
