Directory Server Admin
jtruitt
7-Bedrock
Is there only one admin that's set up at installation? No one in IT knows anything about this or has any kind of password. I tried the DN for the site admin and it didn't seem to work although I'm not sure I did the syntax correctly. Do admins setup through the site, org participant utility have any administration of the DS? Is there anyway to find out the admin info for this?
7 REPLIES 7
BenLoosli
(To:jtruitt)
You may find the password in the log files on the server where DS is installed.
There is also a text file that can be saved when installing Windchill that has a lot of information in it, and should be protected .
Is there a specific log/text file to look for? We found an HTML document with some info on the DN and password but it didn't work.
bkontham
(To:jtruitt)
If you are on Windchill 10.2, as Ben mentioned you will find the password information in 'summary.htm' (<Windchill_Home>\PSI\installer\).
Thank you for the help! Unfortunately we found the file and gave the password and DN a try but it still didn't authenticate. Is this just the initial install password and DN and could have been changed after?
BenLoosli
(To:jtruitt)
Yes, those are what was entered by whomever installed DS and very easily could have been changed later by someone who know the original password. I take it that person is no longer working for your company.
bkontham
(To:jtruitt)
You might find the updated DS password in 'app-Windchill-AuthProvider.xml. You can find it at <Apache_home>\conf\extra.
Hi Jordan,
Could you please share screenshot what you are trying and what error message you are getting ?
Dipak
