Disable printer option
PanneerSelvamM
Hi all,
I want to disable printer option in Product View 9.1.
Is it possible?
If it is possible help me out.
Add following to the Productviw preference file (It can be admin_prefs.xml or server_prefs.xml or user_prefs.xml)
<preferences>
<category name="General">
<subcategory name="UI_Config">
<preference name="disabled_commands" value="PrintCmd"/>
</subcategory>
</category>
</preferences>
Also Is this for particular file type ? (HPGL / PDF / DXF ) ?
For productview Standard refer
https://www.ptc.com/appserver/cs/view/solution.jsp?n=136766
What ProductView 9.1 version? Standard or Professional/Light?
If it's Professional/Light, check the readme.txt file in the "preferences/ProductView" folder. It provides information about disabling commands and locked option settings.
As for the Standard version, I don't know a method do disable access to comands. You still can play with watermarking to make the printed data unreadable.
<preferences>
</subcategory>
</category>
</preferences>
