I am looking for Discussion forum comments to be able to hide it when the user is not created that comment and should be able to edit to the user who has created it,
this we have created an action "edit user comments" which is added in the actions tab where it opens the window which has the comments which can be edited... can anyone help me on this.
Hi Petr,
well basically the idea is too edit the discussion comments, for this we have already created an action called Edit user comments under actions as from your image which i have highlighted below.
this action will open a window which will be having comments which has been added other users on change task which they have either completed/rejected/sent back..
my goal is to check the user who has created the comment from the change task is the same user or not and enable him to edit that comment, and other comments should not able to edit / should be disabled.
could you please give an idea on how to do this, or any similar code snippet for this scenario?
Hi @AK_10813265
So you need a code in the your wizard to get the active user and compare him to the discussion comments if it is the correct user or different.
Then use this information in some JavaScript function to allow/disallow the edit the comment.
Everything depends how you present the discussion in your page.
If it is in the tree table, then you can use some function that exclude the discussion row.
PetrH
Hi Petr,
Thank you for your response, I am looking pretty much on the code and what you have explained in the above comment.
and we wanted to edit it in the table view not in the tree view of the comments.
It would be little more easy if you elaborate more on this, this would be much helpful.
So if you have anything similar code written can you share that?
AK
Hi @HelesicPetr ,
Any idea you can create that for us, that would be much helpful and an idea for the other users by implementing these new solutions.
Ak
