Display the current tool's context
MikeLockwood
22-Sapphire I
No good solution. Seems that the system is "upside down" in that a higher level admin can't even see what is below without going there.
Mike,
Regarding your note about production an test sytems, For fear of that mistake, I edited the "header.jpg" file on my test system tochange it from blue to green. I did that for a few otherwindows backgrounds. Now the signal is clear : if it's green it's not for real.
HTH,
Vincent
Note: Be super careful also about having these UI's open between Windchill systems (e.g. having both Production and TEST open). Super easy to make the mistake of changing production when you think you're changing TEST.
In Reply to Mike Lockwood:
Yeah, several methods of doing that - the "official" process is in the Windchill Customizer's Guide:
[cid:image001.png@01CB1DB3.75B133D0]
Long time since this one was discussed. One advantage to modifying the
header.gif or logoWC.gif is you don't eat up your precious real-estate
with the banner taking up extra space at the top. That was the
immediate complaint of my boss when I turned that on.
Adding the banner feature line to begin_custom.jspf immediately and then
just leaving banner.txt empty sure makes it quick to add and remove
messages when you want them though.
