Iwant to remove the new JSCA table options from the setup participants JSP page. Unfortunately the page isn't constructed with the typical describeTable, renderTable. Instead itis done through java code.
It looks like the table is rendered through this line of code:
NmTableRenderer.draw( modelBean, objectBean, sessionBean, localeBean, urlFactoryBean, actionBean, stringBean, linkBean, nmcontext, checkBoxBean,textBoxBean, radioButtonBean, textAreaBean, comboBoxBean, dateBean, null, null, null, true, out, request, response);
I couldn't find anywhere to set the useJSCA flag to false.
Any help would be appreciated.
Steve D.
What I want to turn off is the scrolling. I had logged a call with T.S. to do this, and they said it was not possible. I've had luck with other tables, but this one is not generated the same way.
it was suggested to
"You can use table.setScrollable(false) on NmHTMLTable used to render the 'Set Up Participants' table. But again this will be an unsupported customization and may also cause some performance issues."
I tried that but it didn't work.
