ESI Error shows "Phantom CAD subassembly publication is not supported"
MB_10725944
I am using Windchill Enterprise Systems Integration Release 12.1 and Datecode with CPS 12.1.0.0
While Publishing the code, there is this ESI Error shows "Phantom CAD subassembly publication is not supported"
I would open a ticket with tech support. You might get the answer that is working to spec. If you do want this supported, I would submit an idea and indicate how you would want the ERP system to handle phantom CAD.
Hi, Please let me know. Need support
When i check the BOM structure there is no Phantom CAD sub assembly that i can see.
