This is Windchill's standard operation when the system checks the data to be sent against the last successfully sent version.
If it finds no differences, it does not execute and write anything.
Take a look also to this article
This is expected you can't send same stuff twice to ERP ,try to revise the object and give a try
Hi @SS_10607365
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
