End Item object from Change Issue and Change Request
  • January 25, 2016
  • 2732 views
Hello Team,
Can any one help to to get the Affected EndItem from the Change Issue and Change Request using Windchill api and dbtable
Best answer by BineshKumar1
Try this
SELECT
  wtc.wtchgrequestnumber as "CRNumber",
  wtc.name AS "CRName",
  wtp.name as "EndItemName",
  wtp.wtpartnumber as "EndItemNumber"
FROM
  WTPartMaster wtp,
  WTChangeRequest2Master wtc,
  SubjectProduct sp,
  controlbranch cb
WHERE
  wtp.ida2a2= sp.ida3a5 AND
  sp.branchida3b5= cb.ida2a2 AND
  cb.ida3b5=wtc.ida2a2;
Thank you
Binesh Kumar
use below API to get affected enditems for CR and see subjectprouct table in DB
ChangeHelper2.service.getSubjectProducts(cr);
Shreyas
adev1-VisitorAuthor
thank you Shreyas or your answer do you also know the database table from there we can get the endItem object
Try this
SELECT
FROM
  WTPartMaster wtp,
  SubjectProduct sp,
  controlbranch cb
WHERE
Thank you
Binesh Kumar
