Error Message for Java While Using ie_in_process
byork
Has anybody seen this message when trying to use the edit attachments tool in the integrated browser in Pro/E. It will work fine if I use ie_in_sep_process setting, but I have some I can't right now. This really feels like some security settings but I have no idea which one.
[cid:image002.jpg@01CEB2F6.859AB290]
Thanks in advance!
RandyJones
20-Turquoise
(To:byork)
There is a Windchill site preference you can set called "File Upload Mechanism". This is set to "Use Java applet functionality to select and upload files" by default. This can be changed to "Use basic browser functionality to select and upload files". The Set Preference dialog gives a fairly decent
explanation of the differences.
> Thanks in advance!
> This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of
> this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
> Attachment Links: image002.jpg (25 k) <">http://portal.ptcuser.org/p/fo/do/download=1&fid=21719> 9-16-2013 3-53-53 PM.png (96 k) <">http://portal.ptcuser.org/p/fo/do/download=1&fid=21720>
> Site Links: View post online <">http://portal.ptcuser.org/p/fo/st/post=120133&anc=p120133#p120133> View mailing list online <">http://portal.ptcuser.org/p/fo/si/topic=16> Start new thread via email <">mailto:-> Unsubscribe from this mailing list
> <">mailto:-?Subject=Unsubscribe> Manage your subscription
byork
(To:byork)
I've tried that setting and still get the same error.
