Windchill returns wrong findNumber
Hi all,
Recently I encountered a very strange Windchill behavior so I would appreciate if anyone can give me a suggestion what I did wrong. I got an assembly with three parts (part-001, part-002 and part-003) I added value for findNumber (in Windchill) attribute for every part (respectively 1, 2, 3) and then I checked in the assembly. After running the webject I got proper result (values for findNumber for the parts as given):
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="INSTANCE" data="<%=wtInstance%>"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="DIRECTION" data="uses"/>
<ie:param name="DEPTH" data="999"/>
<ie:param name="MODE" data="FLAT"/>
<ie:param name="OUTPUT_TYPE" data="OTHER_SIDE"/>
<ie:param name="AUTO_NAVIGATE" data="TRUE"/>
<ie:param name="SELECTEDBY" data="LATEST"/>
<ie:param name="OBJECT_REF" data="<%=obid%>"/>
<ie:param name="ATTRIBUTE" data="obid,name,number,usedFindNumber" delim=","/>
<ie:param name="GROUP_OUT" data="output"/>
</ie:webject>
Then I changed findNumber values a couple of times (checking in the assembly for every change), (last values were 11,12,13). Then I run the webject again and I was suppressed with the result, I did’t got findNumber values 11, 12, 13 but random value from previously added findNumer values.
I don’t know where the problem lies and what to do to get the right value (the last one) for the findNumber, please help.
17:49:15 | |||
Number | Name | usedFindNumber |
0000000545 | sklop-001 | A12 | |
0000000546 | part-001 | 8 | A1 |
0000000547 | part-002 | 9 | A1 |
0000000548 | part-003 | 10 | A1 |
Nenad
