I have added some extra sub types and Standard attributes in windchill 10.0 from admin user in site context. When i try to create any kind of part now, it is giving the above mentioned error.
Thank you all for help. The issue is now resolved. It was a java applet issue. i resolved it by following these steps.
Workaround:
Whats the error in method server log? Which object are you creating? Could you switch to basic browser in your upload preference and try again
Binesh
Surbhi, This may also be helpful:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS54777
You also want to make sure that you are using a version of Java that is compatible with the version of Windchill if you are using Java applet as the file upload mechanism.
10.0 Compatibility matrix can be found here:
When making that setting change it removes the drag-n-drop icons for Change Requests/Change Notices. It's unfortunate that feature has to be turned off so some of my users can complete a CR or CN. The users like it.
I also posted a question about this error.
Workaround:
