Hi All,
PFB method server log which is showing an error even though the Windchill got started successfully. I am not able to see the navigator and other tabs and anything in Windchill as and when I login with the credentials.
Can you please look into this and let me know what can be the solution ?
2016-06-06 16:00:08,380 INFO [main] wt.system.out - ------------------------------------------------------
2016-06-06 16:00:08,387 INFO [main] wt.method.server.startup - Starting MethodServer
2016-06-06 16:00:08,387 INFO [main] wt.method.server.startup - JVM id: 10556
2016-06-06 16:00:08,387 INFO [main] wt.method.server.startup - JVM: Sun Microsystems Inc., Java HotSpot(TM) 64-Bit Server VM, 1.6.0_41 (20.14-b01), 64-bit
2016-06-06 16:00:08,387 INFO [main] wt.method.server.startup - OS: Windows 7, amd64, 6.1
2016-06-06 16:00:08,388 INFO [main] wt.method.server.startup - Host: HYDHTC342032D (hydhtc342032d.ad.infosys.com)
2016-06-06 16:00:08,388 INFO [main] wt.method.server.startup - Class path =
D:\ptc_1\Windchill_10.1\Windchill\codebase
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveClientWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveServerWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\archiveWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\CounterPartWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\dpimplWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\dpinfraWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\Gantt.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\ie3rdpartylibs.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\ieWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\install.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jmxcoreWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-chart-all.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-framework-all.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\jviews-gantt-all.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\mylyn-integration.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\pdmlWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\prowtWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\reqlWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\rialtoWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\RMWebServices.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\wc3rdpartylibs.jar
D:\ptc_1\Windchill_10.1\Windchill\codebase\WEB-INF\lib\wncWeb.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\pdml.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\reql.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\servlet.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\sqljdbc4.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\WbmRegistry.jar
D:\ptc_1\Windchill_10.1\Windchill\lib\wnc.jar
D:\ptc_1\Windchill_10.1\Java\lib\tools.jar
D:\ptc_1\Windchill_10.1\Windchill\tomcat\bin\bootstrap.jar
D:\ptc_1\Windchill_10.1\Windchill\tomcat\bin\tomcat-juli.jar
D:\ptc_1\Windchill_10.1\Windchill\srclib\wnc\WtAsmAgent.jar
2016-06-06 16:00:08,413 INFO [main] wt.method.server.startup - Setting WTContext time zone to Asia/Calcutta; offset: 5.5
2016-06-06 16:00:08,433 INFO [main] wt.method.server.startup - Setting default time zone to GMT; offset: 0.0
2016-06-06 16:00:09,807 INFO [main] wt.pom.properties - wt.pom.maxDbConnections= 15
2016-06-06 16:00:09,807 INFO [main] wt.pom.properties - wt.pom.minDbConnections= 5
2016-06-06 16:00:09,808 INFO [main] wt.pom.properties - wt.pom.dbConnectionsHardLimit= 25
2016-06-06 16:00:09,808 INFO [main] wt.pom.properties - wt.pom.dbConnectionsSoftLimitWaitTime= 0
2016-06-06 16:00:09,808 INFO [main] wt.pom.properties - wt.pom.dbConnectionsWaitTime= 0
2016-06-06 16:00:09,808 INFO [main] wt.pom.properties - wt.pom.connectionCloserThreshold= 0
2016-06-06 16:00:09,809 INFO [main] wt.pom.properties - wt.pom.connectionCloserIdleTimeout= 0
2016-06-06 16:00:09,809 INFO [main] wt.pom.properties - wt.pom.connectionMonitorSleepInterval= 10
2016-06-06 16:00:09,809 INFO [main] wt.pom.properties - wt.pom.lostConnectionCodes= 1012,3113,3114,12571,17002,17401,17008,17410
2016-06-06 16:00:09,810 INFO [main] wt.pom.properties - wt.pom.recoverableConnectionCodes= 0,28,1012,17002,17008
2016-06-06 16:00:09,810 INFO [main] wt.pom.properties - wt.pom.freeConnectionImmediate= false
2016-06-06 16:00:09,810 INFO [main] wt.pom.properties - wt.pom.maxIdleStatementCaches= 0
2016-06-06 16:00:09,810 INFO [main] wt.pom.properties - wt.pom.jdbc.driver= oracle.jdbc.OracleDriver
2016-06-06 16:00:09,810 INFO [main] wt.pom.properties - wt.pom.jdbc.url= jdbc:oracle:thin:
2016-06-06 16:00:09,811 INFO [main] wt.pom.properties - wt.pom.jdbc.host= hydhtc342032d.ad.infosys.com
2016-06-06 16:00:09,811 INFO [main] wt.pom.properties - wt.pom.jdbc.port= 1521
2016-06-06 16:00:09,811 INFO [main] wt.pom.properties - wt.pom.jdbc.service= winddin
2016-06-06 16:00:09,811 INFO [main] wt.pom.properties - wt.pom.jdbc.database=
2016-06-06 16:00:09,812 INFO [main] wt.pom.properties - wt.pom.dbUser= wcadmin
2016-06-06 16:00:09,812 INFO [main] wt.pom.properties - wt.pom.dbSchemaUser= wcadmin
2016-06-06 16:00:09,812 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesNameList=
2016-06-06 16:00:09,812 INFO [main] wt.pom.properties - wt.pom.dbConnectionPropertiesValueList=
2016-06-06 16:00:09,812 INFO [main] wt.pom.properties - wt.pom.dbConnectionRetryCount= 1
2016-06-06 16:00:09,813 INFO [main] wt.pom.properties - wt.pom.userDefinedFunctionsFileName= D:\ptc_1\Windchill_10.1\Windchill\db\userDefinedFunctions.xml
2016-06-06 16:00:09,813 INFO [main] wt.pom.properties - wt.pom.rowPrefetchCount= 20
2016-06-06 16:00:09,813 INFO [main] wt.pom.properties - wt.pom.statementCacheSize= 50
2016-06-06 16:00:09,813 INFO [main] wt.pom.properties - wt.pom.cachedStatementReuseLimit= 50
2016-06-06 16:00:09,814 INFO [main] wt.pom.properties - wt.pom.feedbackInterval= 500
2016-06-06 16:00:09,814 INFO [main] wt.pom.properties - wt.pom.interruptInterval= 50
2016-06-06 16:00:09,814 INFO [main] wt.pom.properties - wt.pom.cachedStatementRSLimit= -1
2016-06-06 16:00:09,815 INFO [main] wt.pom.properties - wt.pom.implicitTransactions= false
2016-06-06 16:00:09,815 INFO [main] wt.pom.properties - wt.pom.implicitTransactionsRollbackTime= 600
2016-06-06 16:00:09,815 INFO [main] wt.pom.properties - wt.pom.navigateDepthThreshold= 4
2016-06-06 16:00:09,815 INFO [main] wt.pom.properties - wt.pom.navigateDepthUnionLimit= 10
2016-06-06 16:00:09,815 INFO [main] wt.pom.properties - wt.pom.queryDepthThreshold= 3
2016-06-06 16:00:09,816 INFO [main] wt.pom.properties - wt.pom.queryDepthInClauseSizeLimit= 50
2016-06-06 16:00:09,816 INFO [main] wt.pom.properties - wt.pom.lobChunkSize= 32528
2016-06-06 16:00:09,816 INFO [main] wt.pom.properties - wt.pom.log.JDBCStatements= false
2016-06-06 16:00:09,816 INFO [main] wt.pom.properties - wt.pom.log.fileJDBC= null
2016-06-06 16:00:09,816 INFO [main] wt.pom.properties - wt.pom.log.filterJDBC= null
2016-06-06 16:00:09,817 INFO [main] wt.pom.properties - wt.pom.chunk.defaultSize= 50
2016-06-06 16:00:09,817 INFO [main] wt.pom.properties - wt.pom.objectReferenceQuerySize= 254
2016-06-06 16:00:09,817 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryChunkSize= 500
2016-06-06 16:00:09,818 INFO [main] wt.pom.properties - wt.pom.objectReferenceQueryArrayTableEnabled= true
2016-06-06 16:00:09,818 INFO [main] wt.pom.properties - wt.pom.inflateHint= RULE
2016-06-06 16:00:09,818 INFO [main] wt.pom.properties - wt.pom.inflateSingleTableMode= true
2016-06-06 16:00:09,818 INFO [main] wt.pom.properties - wt.pom.useBind= true
2016-06-06 16:00:09,818 INFO [main] wt.pom.properties - wt.pom.inClauseFixedSize= 5
2016-06-06 16:00:09,819 INFO [main] wt.pom.properties - wt.pom.inClauseSizeLimit= 1000
2016-06-06 16:00:09,819 INFO [main] wt.pom.properties - wt.pom.inClauseBindLimit= 51
2016-06-06 16:00:09,819 INFO [main] wt.pom.properties - wt.pom.inClauseUseBindOptimization= true
2016-06-06 16:00:09,819 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationThreshold=50
2016-06-06 16:00:09,820 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationTempTableUsePrimaryKey=true
2016-06-06 16:00:09,820 INFO [main] wt.pom.properties - wt.pom.inClauseBindOptimizationCardinality=-1
2016-06-06 16:00:09,820 INFO [main] wt.pom.properties - wt.pom.cardinalityValueFixedSize= 100
2016-06-06 16:00:09,820 INFO [main] wt.pom.properties - wt.pom.tempTableNumberPerThreshold= 5
2016-06-06 16:00:09,820 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeNumberOfThreshold=3
2016-06-06 16:00:09,821 INFO [main] wt.pom.properties - wt.pom.tempTableArraySizeThresholdValues=200,1000, 2000
2016-06-06 16:00:09,821 INFO [main] wt.pom.properties - wt.pom.tempTable.insertChunkSize=50000
2016-06-06 16:00:09,821 INFO [main] wt.pom.properties - wt.pom.startupQueryLimit= -1
2016-06-06 16:00:09,821 INFO [main] wt.pom.properties - wt.pom.queryLimit= -1
2016-06-06 16:00:09,822 INFO [main] wt.pom.properties - wt.pom.paging.queueInvokeTime= 600
2016-06-06 16:00:09,822 INFO [main] wt.pom.properties - wt.pom.paging.sessionCleanupTime= 1800
2016-06-06 16:00:09,822 INFO [main] wt.pom.properties - wt.pom.paging.threshold= -1
2016-06-06 16:00:09,822 INFO [main] wt.pom.properties - wt.pom.paging.insertChunkSize= 250
2016-06-06 16:00:09,822 INFO [main] wt.pom.properties - wt.pom.paging.fetchLimit= 15
2016-06-06 16:00:09,823 INFO [main] wt.pom.properties - wt.pom.paging.fetchSleepInterval= 1000
2016-06-06 16:00:09,823 INFO [main] wt.pom.properties - wt.pom.paging.closeSleepInterval= 600
2016-06-06 16:00:09,823 INFO [main] wt.pom.properties - wt.pom.paging.snapshotQueryLimit= -1
2016-06-06 16:00:09,823 INFO [main] wt.pom.properties - wt.pom.paging.pagingSessionLimit= 5
2016-06-06 16:00:09,824 INFO [main] wt.pom.properties - wt.pom.statementCache.summaryInterval= 2000
2016-06-06 16:00:09,824 INFO [main] wt.pom.properties - wt.pom.enableNLSSort= true
2016-06-06 16:00:09,824 INFO [main] wt.pom.properties - wt.pom.constantArrayTableLimit= 4000
2016-06-06 16:00:09,824 INFO [main] wt.pom.properties - wt.pom.traceTiming.enable= true
2016-06-06 16:00:09,824 INFO [main] wt.pom.properties - wt.pom.blobRead.handle620LV= false
2016-06-06 16:00:09,825 INFO [main] wt.pom.properties - wt.pom.blobRead.handleOldLV= false
2016-06-06 16:00:09,825 INFO [main] wt.pom.properties - wt.pom.blobRewrite.enabled= false
2016-06-06 16:00:09,825 INFO [main] wt.pom.properties - wt.pom.selectForUpdateEnabled= false
2016-06-06 16:00:09,826 INFO [main] wt.pom.properties - wt.pom.refreshCache.enabled= true
2016-06-06 16:00:09,826 INFO [main] wt.pom.properties - wt.pom.refreshCache.summeryInterval= 0
2016-06-06 16:00:09,826 INFO [main] wt.pom.properties - wt.pom.refreshCache.size= 300
2016-06-06 16:00:09,826 INFO [main] wt.pom.properties - wt.pom.enableSQL99OuterjoinSyntax= false
2016-06-06 16:00:09,826 INFO [main] wt.pom.properties - wt.pom.enableInListOptimizationWarning= false
2016-06-06 16:00:09,827 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.chunkThreshold=-1
2016-06-06 16:00:09,827 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.roleChunkSize=-1
2016-06-06 16:00:09,827 INFO [main] wt.pom.properties - wt.pom.refIntegrity.ownerQuery.objectChunkSize=-1
2016-06-06 16:00:09,827 INFO [main] wt.pom.properties - wt.pom.refIntegrity.removeOids.objectChunkSize=-1
2016-06-06 16:00:09,828 INFO [main] wt.pom.properties - wt.pom.batch.spec.tableExpressionThreshold=5
2016-06-06 16:00:09,828 INFO [main] wt.pom.properties - wt.pom.batch.spec.useTableType= true
2016-06-06 16:00:09,828 INFO [main] wt.pom.properties - wt.pom.batch.spec.useColumnList= true
2016-06-06 16:00:09,828 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.classChunkSize= 2000
2016-06-06 16:00:09,828 INFO [main] wt.pom.properties - wt.pom.batch.spec.delete.chunkSize= 5000
2016-06-06 16:00:09,829 INFO [main] wt.pom.properties - wt.pom.batch.retry.enable= true
2016-06-06 16:00:09,829 INFO [main] wt.pom.properties - wt.pom.batch.closePreparedStatement.threshold=-1
2016-06-06 16:00:09,829 INFO [main] wt.pom.properties - wt.pom.batch.insert.chunkSize= 100000
2016-06-06 16:00:09,829 INFO [main] wt.pom.properties - wt.pom.batch.update.chunkSize= 100000
2016-06-06 16:00:09,830 INFO [main] wt.pom.properties - wt.pom.maxQueryRetryCount= 5
2016-06-06 16:00:09,830 INFO [main] wt.pom.properties - wt.pom.oracle.blobExplictOpen.enable= false
2016-06-06 16:00:09,830 INFO [main] wt.pom.properties - wt.pom.oracle.blobInlineWriteThreshold= -1
2016-06-06 16:00:09,830 INFO [main] wt.pom.properties - wt.pom.oracle.disableAlwaysSemiJoin= true
2016-06-06 16:00:09,830 INFO [main] wt.pom.properties - wt.pom.oracle.jdbcConnectionMemoryLimit= 48
2016-06-06 16:00:09,831 INFO [main] wt.pom.properties - wt.pom.oracle.nlssort.truncateLength= 600
2016-06-06 16:00:09,831 INFO [main] wt.pom.properties - wt.pom.emptyTableQueryClassChunkSize = 400
2016-06-06 16:00:09,831 INFO [main] wt.pom.properties - wt.pom.emptyTableQuery.excludedSourceClassNames =
2016-06-06 16:00:09,831 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.size = 7
2016-06-06 16:00:09,872 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.queueSize = -1
2016-06-06 16:00:09,873 INFO [main] wt.pom.properties - wt.pom.resultSetThreadPool.implicitEnabled=false
2016-06-06 16:00:09,873 INFO [main] wt.pom.properties - wt.pom.pdsDecoderBypassUserLoader = true
2016-06-06 16:00:09,873 INFO [main] wt.pom.properties - wt.pom.externalTableValidSchemaNames = null
2016-06-06 16:00:09,873 INFO [main] wt.pom.properties - Windchill DataStore: Oracle
2016-06-06 16:00:09,874 INFO [main] wt.pom.properties - JDBC Driver Version: major=11 minor=2
2016-06-06 16:00:10,116 INFO [main] wt.method.server.startup - MethodServer created - port 5003: MethodServerImpl[UnicastServerRef [liveRef: [endpoint:[hydhtc342032d.ad.infosys.com:5003](local),objID:[-7ac99d0c:15525432e1a:-7ffc, 361763879422843010]]]]
2016-06-06 16:00:10,124 INFO [main] wt.method.server.startup - Starting services - class = wt.services.StandardServicesHandler
2016-06-06 16:00:14,539 INFO [main] wt.pom.properties - wt.pom.delete.triggerClassNames=
2016-06-06 16:00:22,828 INFO [main] wt.pom.properties - Connection: datastore=Oracle(Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options) jdbcVersion=11.2 driver=Oracle JDBC driver(11.2.0.3.0) driverVersion=11.2
2016-06-06 16:00:24,767 INFO [main] wt.util.version.WindchillVersion -
Timestamp: June 06, 2016 - 10:30:24 (GMT: Jun 6, 2016 10:30:24 AM)
Support Support Installer
Datecode Release Number Release Id Sequence Display Label
M050 10.1 pdml.10.1.50.29 01 Windchill PDMLink 10.1
M050 10.1 whc.10.1.50.29 01 Windchill Help Center
M050 10.1 ie.10.1.50.29 01 Windchill 10.1 Info*Engine
M050 10.1 wnc.10.1.50.29 05 Windchill 10.1 Services
There are no patches installed.
There is no non-default locale support installed.
2016-06-06 16:00:25,545 INFO [main] wt.fv.startup - Last generated value of STREAMID_SEQ 16001
2016-06-06 16:00:25,545 INFO [main] wt.fv.startup - Last generated value of FILENAMEUSN_SEQ 16001
2016-06-06 16:00:25,557 INFO [main] wt.fv.startup - max(streamid) from tables = 14001
2016-06-06 16:00:25,564 INFO [main] wt.fv.startup - max(uniqueSequenceNumber) from tables = 14001
2016-06-06 16:00:26,718 INFO [main] wt.fv.info Administrator - Creating secret key.
2016-06-06 16:00:26,765 INFO [main] wt.fv.info Administrator - Secret key generated successfully.
2016-06-06 16:00:27,205 INFO [main] com.ptc.windchill.counterpart.StandardCounterPartService Administrator - CounterPart service: started with classification not checked out
2016-06-06 16:00:27,298 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Starting LoadLogicRepositoryTask.run()
2016-06-06 16:00:27,597 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator wcadmin - Starting initTypeDefinitions()
2016-06-06 16:00:29,541 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator wcadmin - Finished initTypeDefinitions()
2016-06-06 16:00:29,542 INFO [main] com.ptc.core.logic.LogicRepository wcadmin - Logic Repository processing started
2016-06-06 16:00:48,296 INFO [main] com.ptc.core.logic.LogicRepository wcadmin - Logic Repository processing completed
2016-06-06 16:00:48,296 INFO [main] com.ptc.core.logic.repository.server.impl.ChangeLocator - Finished LoadLogicRepositoryTask.run()
2016-06-06 16:00:48,416 INFO [NmActionService.initXml] com.ptc.netmarkets.util.misc.StandardNmActionService.xmlInit - Started initializeXML()
2016-06-06 16:00:54,345 INFO [main] wt.pom.statementCache.summary Administrator - StatementCache: wt.util.Cache%1938282478 [size=50, count=50, hits=2001, misses=156, aged=80]
2016-06-06 16:00:59,051 INFO [main] wt.method.server.startup.services - All managers started.
2016-06-06 16:00:59,052 INFO [main] wt.method.server.startup - StandardManagerService started
2016-06-06 16:00:59,052 INFO [main] wt.method.server.startup - Services started.
2016-06-06 16:00:59,326 INFO [main] wt.method.server.startup - MethodServer registered with ServerManager
2016-06-06 16:00:59,330 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap
2016-06-06 16:00:59,341 INFO [main] wt.method.server.startup - Creating wt.method.WTAdapter
2016-06-06 16:00:59,343 INFO [main] wt.method.server.startup - Creating wt.method.ClusterMonitor
2016-06-06 16:00:59,390 INFO [main] wt.method.server.startup - Creating wt.method.jmx.Startup
2016-06-06 16:01:04,564 INFO [main] wt.method.server.startup - Creating wt.phonehome.queue.PhoneHomeQueueScheduler
2016-06-06 16:01:04,959 INFO [main] wt.method.server.startup - Creating com.ptc.tomcat.embedded.Bootstrap$WaitUntilStarted
2016-06-06 16:01:05,053 INFO [localhost-startStop-1] wt.system.err - Jun 6, 2016 10:31:05 AM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextInitialized
2016-06-06 16:01:05,053 INFO [localhost-startStop-1] wt.system.err - INFO: WSSERVLET12: JAX-WS context listener initializing
2016-06-06 16:01:05,432 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.methodServer.info - JVMName=10556@HYDHTC342032D,
StartTime=1465209003882,
MaxHeapBytes=3347316736,
ServiceName=MethodServer,
JVMArguments=[-XX:+UseCompressedOops,
-javaagent:D:\ptc_1\Windchill_10.1\Windchill\srclib\wnc\WtAsmAgent.jar,
-Xverify:none,
-Djava.endorsed.dirs=D:\ptc_1\Windchill_10.1\Windchill\lib\endorsed,
-Djava.awt.headless=true,
-Djava.rmi.server.useCodebaseOnly=true,
-Dwt.manager.serviceName=MethodServer,
-Dwt.logs.dir=D:\ptc_1\Windchill_10.1\Windchill\logs,
-Dcom.sun.management.jmxremote,
-Djmx.remote.protocol.provider.pkgs=wt.jmx.remote.protocol,
-Dlog4j.configuration=WEB-INF/log4jMethodServer.properties,
-Dwt.tomcat.embeddedMode.enable=true,
-Xms3331m,
-Xmx3331m,
-XX:PermSize=184m,
-XX:MaxPermSize=450m,
-XX:InitialCodeCacheSize=25m,
-XX:ReservedCodeCacheSize=128m,
-Dsun.rmi.dgc.client.gcInterval=3600000,
-Dsun.rmi.dgc.server.gcInterval=3600000,
-Xloggc:D:\ptc_1\Windchill_10.1\Windchill\logs\MethodServer-160606160002670-2-GC.log,
-XX:+PrintGCDetails,
-XX:+PrintGCDateStamps],
AvailableProcessors=2
2016-06-06 16:01:06,340 INFO [wt.jmx.core.SharedScheduledExecutor.worker] wt.summary.general - JVMName=10556@HYDHTC342032D, HeapMemoryUsage=159753104, NonHeapMemoryUsage=149443816, Uptime=62450, ProcessCpuTime=58063572200, JITCTime=39265, GarbageCollectors=[PS MarkSweep,PS Scavenge], GCTime=[685,578], GCCount=[2,4], Classes=15301, Threads=40, TotalStartedThreadCount=46, PermGenPercentCollUsage=29.879511515299477, PermGenPercentUsage=29.879525078667534, CodeCachePercentUsage=6.254148483276367
2016-06-06 16:01:09,482 INFO [localhost-startStop-1] wt.system.err - Jun 6, 2016 10:31:09 AM com.sun.xml.ws.server.MonitorBase createRoot
2016-06-06 16:01:09,482 INFO [localhost-startStop-1] wt.system.err - INFO: Metro monitoring rootname successfully set to: com.sun.metro:pp=/,type=WSEndpoint,name=/Windchill-RMWebServicesImplService-RMWebServicesImplPort
2016-06-06 16:01:09,908 INFO [localhost-startStop-1] wt.system.err - Jun 6, 2016 10:31:09 AM com.sun.xml.ws.transport.http.servlet.WSServletDelegate <init>
2016-06-06 16:01:09,908 INFO [localhost-startStop-1] wt.system.err - INFO: WSSERVLET14: JAX-WS servlet initializing
2016-06-06 16:01:10,010 INFO [localhost-startStop-1] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization started
2016-06-06 16:01:27,207 INFO [localhost-startStop-1] org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'MVCDispatcher': initialization completed in 17197 ms
2016-06-06 16:01:27,251 INFO [Tomcat main] com.ptc.tomcat.embedded.Bootstrap - Embedded Tomcat ready; catalina.base=D:\ptc_1\Windchill_10.1\Windchill\tomcat\instances\instance-8010
2016-06-06 16:01:27,252 INFO [main] wt.method.server.startup - MethodServer ready (in 83.37 secs).
2016-06-06 16:03:03,775 ERROR [ajp-bio-8010-exec-1] com.ptc.jca.navigation wcadmin - problem getting the main navigation action model
(com.ptc.netmarkets.util.misc.miscResource/400) com.ptc.netmarkets.model.NmException: actionmodels.xml file is missing an entry called navigator. Please add the model and restart the server.
at com.ptc.netmarkets.util.misc.StandardNmActionService.getActionModel(StandardNmActionService.java:566)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy35.getActionModel(Unknown Source)
at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getActionModel(DefaultNavigationListDelegate.java:228)
at com.ptc.windchill.enterprise.navigation.delegates.DefaultNavigationListDelegate.getJSONForShell(DefaultNavigationListDelegate.java:590)
at org.apache.jsp.WEB_002dINF.jsp.shell_jsp._jspService(shell_jsp.java:182)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:748)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:486)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:411)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:338)
at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:238)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:250)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1047)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:817)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:669)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:574)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:98)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:253)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1609)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:193)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:65)
at java.lang.Thread.run(Thread.java:662)
at org.apache.tomcat.util.threads.TaskThread.run(TaskThread.java:103)
Resolved
Please let everyone know how you resolved it.
I am also facing the same issue could you elaborate how you resolved the issue.
