I am creating event listener that needs to send a message containing new object id (copy) and old object id (source) to a servlet when some WTPart is checked out. At the first it seems straight forward until I found out that there is no CHECKOUT event but a sequence of events (PRE_CHECKOUT, UPDATE, PRE_STORE, INSERT, NEW_ITERATION, NEW_VERSION, POST_STORE, POST_CHECKOUT) that constitutes CHECKOUT. To make this more complex when creating new WTPart similar sequence is used (PRE_STORE, INSERT, NEW_ITERATION, NEW_VERSION, POST_STORE ). When dealing with more clients doing checkout it’s hard to distinguish source and related copy object id from all incoming events. Nothing about this is in any WcT manual. Listener that I created can catch events and print a message about it.
Can anybody point me to right direction (or source) where I can found some information?
Hi Martin,
you get me thinking, where I did wrong, and the result is that I did not pay enough attention to the type of the event. For example PersistenceManagerEvent handles UPDATE, INSERT, POST_STORE, PRE_STORE, and PersistenceManagerEvent handles PRE and POST CHECKOUT and CHECKIN also, and VersionControlServiceEvent handles NEW_ITERATION, NEW_VERSION.
Thanks again.
Nenad
