Walking into a new year and a strange error message without any system changes (that I know of). When exporting a table of data to Excel (Export to XLSX), I get this error message:
All other export methods appear to complete fine just this one so I've dropped its severity down. This is with WC 13.0.2.4.
Method Server logs show the following:
Caused by: java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:569)
at com.ptc.core.components.forms.FormDispatcher.callWizardCommand(FormDispatcher.java:112)
at com.ptc.core.components.forms.FormDispatcher.execute(FormDispatcher.java:98)
... 64 more
Caused by: java.lang.IllegalStateException: java.nio.file.NoSuchFileException: /tmp/poifiles/poi-sxssf-sheet5099617869605881006.xml
at org.apache.poi.xssf.streaming.SXSSFWorkbook.createAndRegisterSXSSFSheet(SXSSFWorkbook.java:696)
at org.apache.poi.xssf.streaming.SXSSFWorkbook.createSheet(SXSSFWorkbook.java:712)
at org.apache.poi.xssf.streaming.SXSSFWorkbook.createSheet(SXSSFWorkbook.java:104)
at com.ptc.core.components.export.table.AbstractExportToXLS.initialize(AbstractExportToXLS.java:109)
at com.ptc.core.components.export.table.AbstractExportToXLS.<init>(AbstractExportToXLS.java:63)
at com.ptc.core.components.export.table.ExportToXLSX.<init>(ExportToXLSX.java:24)
at com.ptc.core.components.export.table.ExportFileType.getExportListWriter(ExportFileType.java:227)
at com.ptc.core.components.export.table.ExportListWriterFactory.getExportWriter(ExportListWriterFactory.java:32)
at com.ptc.core.components.export.table.ExportListCommands.getExportListWriter(ExportListCommands.java:155)
at com.ptc.core.components.export.table.ExportListCommands.doExport(ExportListCommands.java:97)
at com.ptc.core.components.export.table.ExportListCommands.export(ExportListCommands.java:88)
... 70 more
Caused by: java.nio.file.NoSuchFileException: /tmp/poifiles/poi-sxssf-sheet5099617869605881006.xml
at java.base/sun.nio.fs.UnixException.translateToIOException(UnixException.java:92)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:106)
at java.base/sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
at java.base/sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:218)
at java.base/java.nio.file.Files.newByteChannel(Files.java:380)
at java.base/java.nio.file.Files.createFile(Files.java:658)
at java.base/java.nio.file.TempFileHelper.create(TempFileHelper.java:136)
at java.base/java.nio.file.TempFileHelper.createTempFile(TempFileHelper.java:159)
at java.base/java.nio.file.Files.createTempFile(Files.java:878)
at org.apache.poi.util.DefaultTempFileCreationStrategy.createTempFile(DefaultTempFileCreationStrategy.java:102)
at org.apache.poi.util.TempFile.createTempFile(TempFile.java:67)
at org.apache.poi.xssf.streaming.SheetDataWriter.createTempFile(SheetDataWriter.java:100)
at org.apache.poi.xssf.streaming.SheetDataWriter.<init>(SheetDataWriter.java:74)
at org.apache.poi.xssf.streaming.SheetDataWriter.<init>(SheetDataWriter.java:84)
at org.apache.poi.xssf.streaming.SXSSFWorkbook.createSheetDataWriter(SXSSFWorkbook.java:387)
at org.apache.poi.xssf.streaming.SXSSFSheet.<init>(SXSSFSheet.java:103)
at org.apache.poi.xssf.streaming.SXSSFWorkbook.createAndRegisterSXSSFSheet(SXSSFWorkbook.java:694)
... 80 more
I can confirm that its not a space issue nor is the user running Windchill unable to read/write to /tmp folder.
Not sure of cause but files did not exist. I restarted Windchill and its working now. Very odd but no longer an issue.
All XLS table exports?
Only XLSX and all tables. I think it uses the same code. XLS and CSV and others still function.
What's error line above this?
Nothing interesting:
2026-01-08 09:02:41,716 ERROR [ajp-nio-127.0.0.1-8010-exec-101] com.ptc.jca.mvc.controllers.ActionController <USERNAME>- java.lang.reflect.InvocationTargetException java.lang.reflect.InvocationTargetException
at com.ptc.netmarkets.util.beans.NmCommandBean.execute(NmCommandBean.java:2246)
at com.ptc.jca.mvc.controllers.ActionController.executeWizardAction(ActionController.java:222)
at com.ptc.jca.mvc.controllers.ActionController.processRequest(ActionController.java:125)
at jdk.internal.reflect.GeneratedMethodAccessor1872.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:255)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:188)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:118)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:926)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:831)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1089)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:979)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1014)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:914)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:590)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:885)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:658)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:195)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:140)
at com.ptc.windchill.upgrade.ui.UpgradeMaintenanceFilter.doFilter(UpgradeMaintenanceFilter.java:31)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:164)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:86)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:148)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:88)
at wt.licenseusage.licensing.LicenseFilter.doFilter(LicenseFilter.java:47)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:300)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1675)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:167)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:483)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:115)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:344)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:431)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:905)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1751)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1190)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
at java.base/java.lang.Thread.run(Thread.java:840)
Interesting. The only article I saw said that "poifiles" was missing. Can you confirm it exists under /tmp/ ? Maybe it's a cache issue? Antivirus?
