Export Import Object Types
bmessenger
If you refer to article https://www.ptc.com/en/support/article/CS30168 it says to export your files and then import them in numerical order. I can get to step 4 successfully.
As soon as I try and import the file numbered _0 it fails with wt.util.WTException: Invalid Name: "local.rs.vsrs05.Regain" is incompatible with the domain context "null".
local.rs.vsrs05.Regain is the organization internal name.
I gather file _0 contains the global attributes which in my case exist on the target machine. I would not expect it to error, I would expect it to do nothing in my case.
FIle _1 contains the attributes form the object type parent but it will load successfully, even though it also does nothing in my case.
File _2 does load successfully and does create the object correctly, even if I do not load file _0 and file _1.
Additionally, I need to specify the organization in the loadfromfile command otherwsie it bombs out.
Does anybody know how I cna load the first file, and load attributes that do not exist already?
I'm afraid it is another case of the documentation missing something critical to make this work. I personally have not found any documentation that is foolproof. There is ALWAYS something missing or something assumed.
I will however habve cases whw
0 REPLIES 0
