Steve,
You are correct. When you use the 'Models and Viewavles' option during checkin, a client-side viewable is uploaded along with the CAD document and server-side publishing is not triggered. Although this is good with regards having a viewable immediately upon checkin, there could be an issue since this viewable might not have all the settings configured in the CAD worker recipe file. For example, if you have configured your recipe file to generate PDF output for all drwaings, a client-side viewable will not comply with this setting.
Ravi
