FAST Instream Reindexing
poduvalarun
Can anyone let me know the procedure you are following for reindexing using FAST Instream? If you could share any errors you faced and any workaround you used with FAST it will be helpful. I am on version 9.1.
Arun
LiuLiang
(To:poduvalarun)
Most of our indexing issues can be resolved by restarting Fast services or rebooting Fast server.
For unresponsive status service processes that cause index queue entries piled up, refer TPI 138495.
For re-indexing all objects from scratch, reset index status table in database by dropping the indexstatus table and recreating it.
open Windhcill shell,
cd <windchill_home>\db\sql\wnc\Foundation\wt\index
sqlplus <windchill_schema_user><password>@<sid>
create table indexstatus_bak as (select * from indexstatus);
@drop_IndexStatus_Table.sql
@create_IndexStatus_Table.sql
@create_IndexStatus_Index.sql
Start windchill bulk indexing tool by command :
windchill wt.index.BulkIndexTool
login as admin user and press 1 to start indexing and press 7 to check status.
Good luck.
In Reply to Arun Paranthatta:
Arun
