Version: Windchill 13.0
Use Case: Determine the lifecycle associated with an object in Windchill.
Description:
We have multiple Lifecycles from the original administrator and I'm trying to find which ones have been used by objects so I can reduce the number of old lifecycles.
Is there a method to do a search in Windchill by Lifecycle to return which objects it is associated with?
My second possible search would be in the Oracle tables but I don't really have any idea where to start with them in SQLDeveloper. I do have a test system that I can play with so all my production data is safe.
try with below SQL
SELECT
pm.WTPARTNUMBER AS "Part Number",
ltm.name AS "Lifecycle Name",
lt.ITERATIONIDA2ITERATIONINFO AS "Lifecycle Version"
FROM
WTPart p
JOIN wtpartMaster pm ON pm.ida2a2 = p.IDA3MASTERREFERENCE
JOIN LifeCycleTemplate lt ON lt.ida2a2 = p.ida3a2state
JOIN LifeCycleTemplateMaster ltm ON ltm.ida2a2 = lt.IDA3MASTERREFERENCE;
also you can create QML report to get the details of lifecycle assigned to object. attached is sample report for WTPART.
Hope this helps.
You can also do this using query builder. It's just a join from the Life Cycle Template, to the object:
