Find tab not coming in part info after inserting new classification attribute
dchavan-2
Here in classification tab find option ins not found
Go to Classification Administration > Manage Classifications
Click on one of the node names you would like to be able to use
Under Properties, is Instantiable set to Yes?  At least one node has to be set to Yes.
Is the classification structure empty (have you defined nodes yet?)
And are you sure you set up the binding attribute correctly using the com.ptc.csm.default_clf_namespace constraint:
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/WCClassAdmin_DefineClassBindingAttr.html
dchavan-2
(To:CaitlinWheeless)
I am binding attribute correctly pl check snap
dchavan-2
(To:dchavan-2)
still its showing blank tab
dchavan-2
Thanks Caitlin its work
