Hi
We have a workflow expression robot that needs to find the Active Related
WTpart linked to the CAD EPM Document Object. Does anyone have an example
of Java with the PDMLink methods to accomplish this that they could share
We are migrating from 8.x to 9.x and the method we are using in 8.x
workflow seems to no longer be available in 9.x, any help is appreciated.
Our current method robot does as follows:
Uses a query to find objects on a baseline.
wt.fc.QueryResult qr =
wt.vc.baseline.BaselineHelper.service.getBaselineItems((wt.vc.baseline.Baseline)refBL);
Loops through the baseline objects and if a CAD .prt or .asm, attempts to
find the Active WtPart linked to it.
The method call we use in our 8.x environment is:
wt.fc.WtObject tPrtx;
tPrtx = wt.epm.structure.StructureServiceUtility.getBuildPart(tPrt1);
tPrt1 is the CAD EPMDocument Object.
Don Thompson
Desk: 616-654-5292
Cell: 616-836-8761
