Hello everyone
I am trying to rename many EPM Documents in PDMLink 9.1 using the Java API. I understand how to set the Name and Number of EPM Documents using the EPMDocumentMasterIdentity class but I am having problems renaming the EPM File Name (CAD Name). I am trying to use the code below.
empDocObject.setCADName(strNewName);
But I do not see a service class to execute.
I also tried the code below to rename the File Name but it is Deprecated. It works but it corrupts the EPM Document and Pro/E can not retrieve it.
wt.epm.EPMDocumentHelper.service.changeCADName((EPMDocumentMaster) docMaster, strNewName);
Anyone have any ideas? Thanks
