Getting Usage link attrubutes API
WM_9965332
Is there an API  to retrieve the uses attributes in the part structure for WTPart?
Attributes such as Line Number, Quantity, Unit, Trace Code, Reference Designator, Find Number.
1 ACCEPTED SOLUTION
Hi @WM_9965332
You can use something like this:
QueryResult qResult = WTPartHelper.service.getUsesWTParts(primWtp, new LatestConfigSpec());
while
(qResult.hasMoreElements())
Object[] obj = (Object[]) qResult.nextElement();
WTPartUsageLink link = (WTPartUsageLink) obj[0];
WTPart subWTP = (WTPart) obj[1];
long lineNumber = link.getLineNumber().getValue();
double amount = link.getQuantity().getAmount();
String unit =
link.getQuantity().getUnit().getStringValue();
String traceCode = link.getTraceCode().getStringValue();
PetrH
5 REPLIES 5
Hi @WM_9965332
while
String unit =
PetrH
Thank you! Is there a way of getting the enumerated display value?
For instance, for unit I'm getting wt.part.QuantityUnit.ea instead of ea (each). And for tracecode I'm getting wt.configuration.TraceCode.0 instead of Untraced
Hi @WM_9965332
If you use IDE to write code, you should find the methods you need.
PetrH
Awesome! It worked for me, thanks! Is there an api to fetch reference designator? I don't see that in the api list but it is a usage link attribute
Hi @WM_9965332
Actually direct method does not exists.
So you need to use PersistableAdapter. (don't ask why :D)
PersistableAdapter paObject = new PersistableAdapter(link, null, null, null);
paObject.load("referenceDesignatorRange");
Object referenceDesign = paObject.get("referenceDesignatorRange");
 The object is value of reference designator but I do not try to check if it is String or other Java Object. It is up to you >D.
Hope this help you
The information is in Article cs47438
PetrH
