Getting value of IBA by Java
VladiSlav
Hello everyone!
I tried to get the values of global attributes through RMI, I could not do it.
Tell me, please, how can I do it?
Are there other ways in java to do it?
For example, through the odataWeb.jar library classes?
Thanks in advance!
Respectfully!
hlafkir
(To:VladiSlav)
Hi
Please check this sample where you will be able to update an IBA via RMI invocation. Note that you not have to check out the document if you want to only read the IBA value. :
public class updateIBA implements RemoteAccess {
	public static void main(String[] args)
	     // Retrieve a MethodServer remote reference
	     // from the ServerManager
	     RemoteMethodServer rms = RemoteMethodServer.getDefault();
	     // Authenticate using the default
	     // HTTPLogin Authenticator
	     rms.setUserName("wcadmin");
	     rms.setPassword("ts");
	     try
	         rms.invoke("update",
	              "ext.training.updateIBA", null, null, null);
	         System.out.println("Should have worked, check the MS log");
	     catch (Exception e)
	         e.printStackTrace();
    public static void update()
         try
                    ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.doc.WTDocument:2956425");
                    WTDocument object = (WTDocument) PersistenceHelper.manager.refresh(oid);
                    Folder folder = WorkInProgressHelper.service.getCheckoutFolder();
                    CheckoutLink cout = WorkInProgressHelper.service.checkout(object, folder, "checkedout");
                    WTDocument manuf_copy = (WTDocument) cout.getWorkingCopy();
                    PersistableAdapter obj = new PersistableAdapter(manuf_copy, null, SessionHelper.getLocale(), new UpdateOperationIdentifier());
             obj.load("intt");
             obj.set("intt", "158");
             object = (WTDocument) obj.apply();
             PersistenceHelper.manager.modify(object);
             WorkInProgressHelper.service.checkin(object, null);
         catch (Exception e)
VladiSlav
(To:hlafkir)
Thank you very much for your reply!
After starting, I have the following error:
wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
	java.lang.NoSuchMethodException: com.com.acme.Test.update()
What am I doing wrong?
