HTTPAuthentication - login failed with RemoteMethodServer
NicolasdeMauroy
Hi, I am using Windchill 9.1 M010, and I am trying to query parts I have on the server through a RemoteMethodServer connection. I do manage to connect on the MethodServer from my client, and to perform trivial things (like getting my SessionContext id). However, while performing a search using PersistenceManager.find(queryspec) method, I cannot access real data. More precisely, I can execute queries that do not return anything, and this works fine, but when I execute a query that is supposed to return objects (WTPartMaster), I have an exception showing "ERROR : wt.httpgw.HTTPAuthentication - HTTP login failed: client host = (my ip address here)" The test is performed with both the client and the windchill application running on my machine. It would be great if anyone could help me solve that one.
Hi Nikolas I writed sample java code 1 sample Author of PDM site4customizer.com
hi Ivan,
I cannot access ur sample code from the above link.
Can u please post it here or provide another link.
