Has anyone ever successfully generated an IP1752 from the BOM report feature?
stoland
It would be a great feature to have it it was successful, and we didn't have to deal with time consuming work arounds.  Even after we set applicability to parts that don't have compliance, the report is missing data, and the XML doesn't import into a builder.  If anyone has had luck, please share your secret.
If no one has luck, is there interest to have this report work?
rfranz
7-Bedrock
(To:stoland)
If you have searched a BOM, and clicked its Company Part, select in the Actions menu Generate IPC-1752 Report then Go.  After a couple of prompt screens the xml is fully generated.  This assumes your supplier data is Full Disclosure for all the parts in the BOM, at least if you desire a Class D.  Otherwise I don't understand your problem.
