Hello PTC Users,
Have you tried to hide the attachments linked to PR or Document (application data) . Basically the WTDocument info page should be visible to the users but the attachments should be hidden . Foget the ACL's , I tried to check if Security Labels would be helpful , but unfortunately they are supported for Document / PR and not for the attachments linked to these objects. Moreover Application Data column in DB has no column for Security Label ! ...
Any help would be highly appeciated and highly useful. Thanks
Sriram Rammohan
Sriram,
if you want to remove attachment from WTDocument > content Tab then you can remove the action from DocumentManagement-actionmodels.xml
if you want to hide that table for some user then you can write validator to hide that table for some user
Hope this helps !!!
Shreyas
Thanks guys for the solution . I prefer to use Filter to hide the tables based on the Groups. Thanks once again !
