How To find all "0" Level Parts from Windchill
vuchekar
Hi all,
I am Exporting Multilevel BOM from Windchill by API.. it Works..
now i want to export all BOM's present in Whindchill, so first i need to be find out the "0" Level Items from Windchill.
Plese let me know how i can do this ?
How i can find the TOP_LEVEl Parts from Windchill..
Vivek
KD
(To:vuchekar)
In this line QueryResult rs = WTPartHelper.service.getUsesWTPartMasters(part); you are passing the part variable value as null which is leading to error.
Thanks and Regards,
Kaushik
6 REPLIES 6
KD
(To:vuchekar)
Hi Vivek,
you can use queryspec to querying the database to get all the end items
If you use "End Item" to track top level assemblies , you can query the DB as Kaushik said.
if not , you have to query all WTPartsMasters, where the oid (ida2a2) does not exist is the WTPartUsageLink table (ida3b5). ie WTpart that are not used as child in a BOM.
You can do that query by API
Hi All,
I found a new way by using partUsageLink to find the TOP level parts from asm, but the code gives some error,
Please can you help me to sort out issu.
Code is:
WTPart part = null;
while(rs.hasMoreElements()){
System.out.println(""+rs.size());
System.out.println(part.getNumber()+"----Has----Child---"+rs.size());
WTPartMaster partMaster=(WTPartMaster)part.getMaster();
QueryResult qr_parents=WTPartHelper.service.getUsedByWTParts(partMaster);
while(qr_parents.hasMoreElements()){
WTPart parentPart = (WTPart)qr_parents.nextElement();
System.out.println(partMaster.getNumber()+"----Has----Parents---"+parentPart.getName());
partMaster =(WTPartMaster)parentPart.getMaster();
KD
(To:vuchekar)
Thanks and Regards,
Kaushik
vuchekar
(To:KD)
Hi Kaushik,
Thanks for your reply,
I need some more help from you, if u don't mine.
I want to create a very Simple WTPart and WTDocument by using Windchill API,
for that i raise a query to PTC tech support but unfortunatly i not gting any code from them,
can you share the very simple code to create WTPart nad WTDocument ?
Vivek
KD
(To:vuchekar)
Hi Vivek,
The basic code to create WTPart.
WTPart part = WTPart.
newWTPart(“Myname”,”MyNumber”);
try {
part.setContainer(container);
Persistable persistable = PersistenceHelper.
manager.save(part);
catch (WTPropertyVetoException e) {
TODO
Auto-generated catch block
e.printStackTrace();
you can also use the code in workflow.
For document use WTDocument.
If you want to create Subtype if WTPart.
use
part.setTypeDefinitionReference(TypedUtilityServiceHelper.service.getTypeDefinitionReference("wt.part.WTPart|com.ptc.ElectricalPart"));
See the various methods in LoadPart and LoadDoc class for better understanding.
Thanks and Regards
Kaushik
