I am looking into the Common Name attribute and the possibility of using it in my company. I would like to hear from those of you who are using the Common Name attribute and what set of variables you are using. Has anyone made it manditory for users to use this attribute. Taken it one step farther and checked for a matching variable when checking objects in?
We have started to use the Common Name as it solves a number of issues that we were facing, the main one being that it was nearly impossible to know what you were looking at in Windchill using basic search.
We had been exposing an internal Pro/E parameter mapped to an Windchill attribute (carried over from Intralink 3.x) but it was inconsistently used, was only in part and assembly models (not drawings) and could only be found using Advanced Search. The best thing about Common Name is that it's a consistent way of identifying things, is available for ALL types of CAD files by default and is part of basic search.
Our CAD file naming scheme uses part numbers or project numbers as the filename:we have been trying to discourage users from naming development files with filenames that use words in them like "ball_bearing.prt" or something like that. The main reason is to ensure uniqueness across the system and this is where the Windchill Name (Common Name) is very useful, as it doesn't have to be unique: only the NUMBER and filename have to be. Since the Name is always visible it becomes the way that one can tell what an object is, rather than using the filename to convey that information. Also since filenames have to be unique you can't use filenames more than once for similar objects.
Our CAD model OIR currently sets Name=NUMBER=filename, unless the Common Name is filled in when creating a new file: then it's just NUMBER=filename. I believe this is pretty common practice.
The biggest hurdle I've had in doing this is trying to get the users to understand the difference between Pro/E and Windchill terms. This is a royal pain. Eyes glaze over when you say that "Name" in Pro/Engineer is equivalent to "filename" in Windchill, Common Name in Pro/Engineer is equivalent to "Name" in Windchill, and that NUMBER in Windchill isapplied by the system. (Mention "Object Initialization Rules" to most of my colleagues andyou've lost them immediately :-)).
Object identity becomes very important as the data set grows, the CAD user base changes and the system begins to be used by non-CAD users. We had never documented any guidelines for naming CAD models and we realized that we needed to do this so that the objects would be classified consistently. We have been renaming legacy objects during the revision process (and related objects too) as well as enforcing use on new objects, to bring the Common Name into day to day use: it's a huge task and will take a long time to complete, but it'll be worth it in the end. I've already had positive feedback about it.
My biggest regret is not recognizing what value Common Name had as we could have started using it many years ago in Intralink 3.x.
In my past implementation with the help of www.Najanaja.com, we used ProE Common Name to be mapped to Windchill Name/Title. See attached email. I've been doing this since the first implementation of Windchill PDMLink 6.2.6. That way Windchill OOTB searches for Number, Name looks like a BOM report and don't need extra entries of duplicated IBAs and ProE parameters.
I should have mentioned that we now use PTC_COMMON_NAME:D as the main drawing title, sowe use the Common Name as the descriptive term in both Windchill and on drawing formats. We still use a parameter /attribute to track the product group name: this is something that would be useful as a system level attribute.
I agree with Mike about the best way to use Name / NUMBER / filename, however, with a tried and true legacy numbering scheme and15+years worth of CAD data, autonumbering isn't an option for us at this point. It would require a level of customization that we can't implement at this time. I'd love to have the system automatically generate both project numbers and released part numbers, but that's science fiction for us at this time.
In one of my previous positions, we attempted to follow the MIL standard for naming files. We were provided rules by the Army to be used in conjunction with the MIL spec. In all cases where special characters showed up that could not be used in the File Name or Number within Windchill, an underscore was implemented instead. This basically boiled down to all special characters except underscores and dashes being converted into an underscore.
The parameters showing it on title blocks and such were not tied to the Windchill attributes Number or File Name. It was left up to the individual to make sure they matched.
Then it was simply a matter of teaching the user base to properly fill in Name when creating a new Pro/E file.Common Name was used as a description/nomenclature with some wicked relations to parse it into three lines for the title block.
(Some time ago I posted the relations on the boards and a PTC rep came on to let us all know line wrapping for a single parameter was planned forWF5. Not sure if it made it in after the rebranding toCreo.)
In Reply to Joseph Cugini:
I am working through an Intralink 3.4 to 9.1 (10.0) migration and would
like to take the time to address a number of bad practices that I
inherited with the original implementation of Intralink 3.x. Primarily,
the release and CAD part naming process. Our site is currently document
centric and we have a Teamcenter implementation for the CM control of
drawings. As for the CAD objects we utilize as-stored configurations
stored Intralink. Our CAD part naming convention is a butchered
combination of part numbers and descriptions while our drawings follow
our internal numeric convention.
Going forward, I would like to enforce the use of "COMMON_NAME" for the
part description and have the ProE part name = the part number. The
issue of course is what to do with special characters. Mil standard
hardware for example shows up on the PL with "/" in the file name. I
would imagine the immediate solution would be to designate a parameter
on the CAD object called "part_number" and make it a string variable.
While that solves the issue of having special characters in the part
number, it doesn't prevent users from creating duplicate parts in the
database with the same part number and thus making it extremely
difficult to CM/revision control the models.
Can anyone offer insight on how to handle special characters in part
names or how to make a designated parameter in 9.1 a key field so that
the system ensures it is unique prior to a check-in.
Joe
If you are referring to the ProE/WGM PTC_COMMON_NAME, in my past implementations, we have mapped it to the ERP material description and the PLM Windchill System Name. We also applied some customization to behave like an IBA. So you can change the NAME like a BOM, and the name has history. The workaround for using the save as history doesn't cut it. We just want the default Product Structure and EPMDocument Structure to behave like a normal BOM. I thought it was a more refined solution than having the ProE file+extension appearing for Windchill NUMBER, NAME and FILENAME. Use the attriubutes what they were hopefully architected for. To have the behavior of Pro/I X3 is just redundant.
