Hello everybody,
In the Windchill 10.1 M40, was possible to configure a folder path fixed to create some Types.
<!-- set the folder -->
<AttrValue id="folder.id" algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm">
<Arg>/Default/THALES/RIDs</Arg>
</AttrValue>
But now In Windchill 10.2 M20 this process doesn't work.
Does anybody already made it in Windchill 10.2 M20???
10.2M020 is working for me with following xml code
<Arg>/Default/Parts</Arg>
</AttrValue>
<!-- specify AttrConstraint tag -->
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
Hell,
It's necessary to add this line in OIR :
<Value algorithm="com.ptc.core.rule.server.impl.GetRendererConstraint">
<Arg>SelectGeneratedFolderByDefault</Arg>
</Value>
</AttrConstraint>
Best regards
Pascal
</AttrValue>
</AttrConstraint>
Thank you!!!
It's Works with me too!!!
=D
