How can i rename the viewable content from representation?
CH_10078393
6-Contributor
HelesicPetr
(To:CH_10078393)
Hi @CH_10078393
It would be nice to be more specific. What you need?
What content are you talking about? additional files? img files? ol files?
Usually user is not allowed to change file name of visualization content.
There can be Afterloader that is activated after visualization and you can manipulate with the visualization content by API as you need.
CS216668
PetrH
Hi Petr H,
I have configured the AfterEDRloader, but this afterEDR loader is triggering when the user is manually create new job and sent for publishing.
But, how can make this afterloader to trigger when the object is checked in ?
our business rule for the publishing is on checkin in action.
Could you please suggest me on it ?.
HelesicPetr
(To:CH_10078393)
Hi @CH_10078393
The AfterEDRloader is also triggered after check-in.
You do something wrong.
You should set debug logging to get information what is wrong.
Do you use Publish Rules?
PetrH
Hi PetrH,
Yes, we use the publishing rules,
publish after Check in.
Chandra
