How can we create a child part in windchill using java api?
saitha
Hi friends,
mrane
(To:saitha)
You'll have to create the child part just like you would create a normal WTPart . Then using WTPartUsageLink you need to link the parent and the newly created WTPart as child.
From object
From relation
Link object
To relation
To object
Comment
wt.part.WTPart
usedBy
wt.part.WTPartUsageLink
uses
wt.part.WTPartMaster
Windchill Java doc will have further info on this.
-Malavika
LoriSood
23-Emerald I
(To:saitha)
Sandeep,
Were you able to get what you needed based on Malavika's response?
