I work in Sourcing and quite often need to create RFQ - Request for Quote with suppliers that need complete product specifications to go with it.
Given a multi-level product structure, is there a feature in Windchill that allows me to download all related objects (drawings, material specs, etc.) at once?
Currently, I am going item by item in the product structure and downloading one document at a time.
Your help is much appreciated, thank you.
Hi Flavio Kalinin,
I've moved your thread to the Windchill community space for improved visibility. This is likely to be a discussion many others will benefit from.
Thanks for sharing.
You can use packages to create collection of object and Deliveries to download content in zip flies.
OOTB packages/Delivery also has feature to send the zip file in email attachment. Refer below help center link for more details
http://support.ptc.com/cs/help/windchill_hc/wc110_hc/index.jspx?id=PackageCreateOview&action=show
Hope it helps
Shreyas
