I am creating a new Role which I need to add to about 350 existing Products in my Windchill installation.
It appears that my only option is to add that Role to each Product Team one Product at a time.
And, or course, then I will need to add Members to that Role in each Product..., which also appears to be a "one Product at a time" ordeal.
Has anyone discovered a method to add a new Role to MULTIPLE existing Product Teams all at once?
Likewise with adding adding Members to that Role all at once across all the existing Product Teams.
Note: For future Products, I am creating a new Product Template which will contain the new Role..., but adding the new Role to existing Products Teams quickly is a problem.
Thanks in advance.
Wow - 350 Product contexts.
In this case, probably best to load from CSV convered to XML via a Windchill shell command.
One example:
Likely will want to also add group(s) to the new Role. Here is a related article:
This can and should be automated using a script.
What version of Windchill are you on?
What's the name of your new role?
Do you have a map or file that maps the user(s) you want to add to the new role in all 350 Products?
<Product Name>=<username>
Or can you get the user from some other logic such as the users in Role X in Team Y
or
the users in Group Z.
Anything to get them data using logic rather than manually?
David
