How to Export Oracle Dump between two specific dates.
VivekUchekar
7-Bedrock
Hi All,
Normally we use Oracle export Command to Export oracle Dump. i.e.
exp system/manager file=E:\backups\OracleMetadata\productionplmdb.dmp owner=dbuser log=E:\backups\OracleMetadata\productionplmdb.log statistics =none
In this case we export all data from databse to .dmp file and then import it to when u required.
now i need only data within specific dates like. i want oracle dump files from 1 dec 20011 to 5 dec 2011 from the enitre databse.
Then for This Condition what will be the export Command, and how i can import this perticular data to Oracle without overriding other previous data present in database.
Thanks and Regards,
Vivek Uchekar
0 REPLIES 0
