Need to bulk load variance objects. Please provide ways to achieve this functionality.
[Knowledge Hub] Windchill PLM - Data Loading
This article is for older version but I do not think csv2xml supports variances. I had to do this for a project and I ended up creating my own loader via a Java command line program that took in a tab delimited file. Short answer, you cannot via loadFromFile.
Could you please help me on the steps to create the custom loader to achieve this. Need to load variance objects in bulk.
As per article https://www.ptc.com/en/support/article/CS322524 it is not possible to load variance,
You can create a custom utility or loader to achieve the same. I can help with utility.
Regards
Ajit
