Hi All,
Good Day To You..
I need to perform rehosting process to move PDM Essentials from one machine to another machine.
As I'm doing this for first time, I need step by step process to rehost.
I kindly request you to guide me to complete this process.
Thanks In Advance
Regards
Krishna Chaithanya
Checkout the Rehost Guide, https://support.ptc.com/view?im_dbkey=162020
Not sure why it doesn't show up as a PDME admin guide, but the process should be the same.
Yes, PDM Essentials uses the same rehost process as PDMLink, so you can use rehost guide that Dan linked to. Also, see CS178253
