How to add Custom Parameters on Title block of 2D Drawings Format or in Parameter section
@_1647
Version: Windchill 12.1
Use Case: Add Custom Parameters on 2D Drawings format or template
Description:
Hi Everyone , I am working of  automation of title block and I want to add  custom parameters on 2D Drawings like ECN Number, TASK Assignee , Task Reviewer, Task Assigned Date and Reviewed Date etc. So currently I have one delegate which gives me the required parameters but that is executing When I add any drawing in Workspace .
So is there any other workaround to add custom Parameters on drawing format or in Parameters Section of Creo at the the time of upload or save or Check In from  WS or anything else .
Please suggest me
5 REPLIES 5
avillanueva
23-Emerald I
(To:@_1647)
When you say delegate, you are saying you have a customization that pulls these parameters from related objects and links them to the CAD object on add? Stepping back, I would caution this whole approach. You are essentially saving in dynamic information that can change at any time into the drawing or CAD object file. This information can be changed with the drawing checked in and not modified leading to a situation where the data becomes out of sync. You also have a case where the drawing needs to be touched again after these tasks are complete to get the date fields of those events. Are you also carrying these IBAs on the CAD objects?
Have you looked at a check-in listener?
@_1647
(To:avillanueva)
Hi Avillanueva,
Thank you for the information.
Yes it is correct that data will be unsynchronized but in our custom logic we have added some validation.
Example : If .drw In RELEASE state only that time parameters will get added or that particular line of code will get execute else it won't,
So I think here we can control dynamic data.
And I will try to create one of checkin listener so will check it will execute or not.
And can you help about this configuration
https://support.ptc.com/help/windchill/r13.0.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_ProEWCIntegCustDwnldServiceParamCust.html
Because I have added this value as it is to preference but on download no any parameters are getting added.
Regards
Vipul
@_1647
(To:avillanueva)
Hi Avillanueva,
Have you ever used check in. Listener for the same.
If yes then please suggest me that how can I update the custom parameters values dynamically on drawing format on check in listener.
Because now I could not able to understand that how it will happen.
 if I apply the format at the time of new drw creation and later only from windchill I checked out and updated the details and again checked in the drw then how drawing format will take updated values ?
Is there any configuration we would need ?
Because I don't have below mentioned IBA's on drw.
I agree with @avillanueva, I wouldn't recommend this approach. It would be better to not store this info directly on the drawing as it can get out of sync. If you do need some info on the drawing, you could look into watermarking as a way to add dynamic information as part of PDF publishing.
@_1647
(To:joe_morton)
Hi joe_morton,
We are trying to achieve this functionality but we don't want dependency of creo parametric for delegate we need a Creo Parametric.
But our thinking and requirement is  User/Reviewer can use CREO VIEW to check or review the drawing.
So Is there any way to update the drawing template or format dynamically from workflow only , on the basis of state change or something else. ??
We can achieve this by using watermarking on representation on publish event but that is last option and we want drawing format should get updated dynamically .
