Hi , I am not able to assign one user-defined role say ROLE_1 to another user-defined role ROLE_2.
Is it possible in Windchill10.1?
I got the following information from Windchill help guide:
Assigning Roles to Roles
Click OK to save your changes and close the window.
Thanks and regards,
Shweta
Hello
I don't think you're able to add a role in a role in a lifecycle definition, even in 10.1
It seems to be a mistake in the help guide
you can define roles in lifecycle :
you can then assign users, group, actors (for example creator of the object), org ... directly in the lifecycle.
,but you should better use a team instance or a container team to map users or groups to your role
regards
Gregory
Hi
Thanks for the response...I was hoping that smthing like this would be available OOTB..
Thanks a lot again.
Shweta
