How to associate a part to a document
ptc-4767031
My requirement is -
there is a soft attribute in my document creation page called drawing number.
This drawing number will take part number as input.
Then it will associate the part with the document.
I have been able to craete the link, the document is shown under Details Page of the Part under Related object tab->Described by Document where as my requirement is
the part should be shown in Document Details Page->Related Objects tab->Describes Parts
5 REPLIES 5
Hello
are you talking about CADDocument or Document ? I assume CAD cause you are talking about drawing ..
if yes, the link to use is epmdescribelink. And the 2 tables should show objects as you describe in your requirements. As it is the same link , which is navigated from both side ...
regards
KD
(To:GregoryPERASSO)
I think it's Document not CADDocument and soft attribute's name is drawing number
sowoh
3-Newcomer
(To:ptc-4767031)
If you are creating the relationship from a part to a document it would either be an WTPartDescribelink if you are linking to the revision or WTPartReferencelink if you are linking to the master ( floating) reference.
HugoHermans
(To:sowoh)
I few days ago, I posted a similar question, see Owner-Content relationship for WTDocument - PTC Community. For CADdocuments, you have one owner link but multiple content links possible. We would like to implement a similar concept for the WTPartDescribLink.
sowoh
3-Newcomer
(To:ptc-4767031)
We have an character string with a pick list at the UI that breaks the related document into how it is related. For example owning or reportable or non-reportable reference data. We use it on both the describes and reference by links.
