Hey Guys,
i have a little question regarding the change task creation. I want to check at the creation of a change task, if the name of the CT equals a document name (e.g. check with a small function if it equals). Because the name of the task should be the same as the document, otherwise there should be no possibility to create the CT. I would guess it can be done through the OIR like the auto numbering? But how do i implement it there?
I am grateful for all ideas, suggestions and incentives. If you need more information, please don't hesitate to ask.
Best Regards,
Ad
