How to check users active on each node in a windchill cluster environment
AP_10483126
Version: Windchill 13.0
Use Case: How to check users active on each node in a windchill cluster environment
Description:
Just curious what the Server Manager shows for active users?
This is from the Server Status MBean dump. I do not have a cluster but I guess if this is not right, you looking to see how they split out?
This shows all the active users in the windchill not as per each node.
you are correct sorry i miss took the screenshot
