promotion request window doesn't popup automatically
ptc-107129
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS30
After checkin via stand alone Edge browser a promotion request window doesn't popup automatically.
Fadel
23-Emerald I
(To:ptc-107129)
do you see that accorss all browsers ? any errors in logs ?
Fede
ptc-107129
(To:Fadel)
In which log file should I have a look?
It works fine with the embedded browser, but not with the stand alone browser.
Errors would appear in Methodserver logs. There might be multiple running so you might have to check each on about the time of check in. If you are expecting a popup, are popup blockers off?
