How to create a custom attributes in windchill using api ?
saitha
Hi Friends,
How to create a custom attributes in windchill using api ,Can u suggest any api ?
Sandeep
You mean to create the attribute (Global Attribute or Soft Attribute)? Or do you want to set an attribute value?
Hi
Yes,I want to create the new attribute through api like name,number (not setting the value)
Sandeep
KD
(To:saitha)
Hi Sandeep,
Use wt.iba.definition.DefinitionLoaderWithCahce.createAttrDefinizer method to create global attribute.
Tanks And Regards,
Kaushik
LoriSood
23-Emerald I
(To:saitha)
Sandeep,
Did Kaushik's suggestion work for you?
