How to download all visualizations
srohde
Hi Community,
in one of our current projects we need to download all visualizations available in Windchill. As we noticed visualizations in windchill are not connected to the filevault via database tables.
How can we get to all the visualizations available in windchill? They may be available in the file vaults, since there are a lot of files in file vaults, not available in epm document file tables, but where can i get the real file names?
Stefan
satre-2
(To:srohde)
Below is sample SQL will give you the links between tables and actual file location in local drive
select ap.fileName,fvm.path ,ad.filesize ,
fvm.path || '\' || to_char(fvi.uniquesequencenumber,'0000000000000x') as VaultName
from
ApplicationData ap,HolderToContent hc,DerivedImage de,FvItem fvi ,FvFolder fvf , FvMount fvm
where
hc.idA3B5=ap.idA2A2 and de.idA2A2=hc.idA3A5
and ap.idA3A5=fvi.idA2A2 and fvi.idA3A4=fvf.idA2A2
AND  fvm.idA3A5=fvf.idA2A2;
Hope it helps !!
Shreyas
7 REPLIES 7
ChrisSpartz
(To:srohde)
You could write a DB query to get the filevault location of all the visualizations. The DB table that stores information about visualizations is the DerivedImage table.
Hey Chris,
thank you for your answer. Do you know how the DerivedImage table is conncted to the fvitem table? Or how do i find out the where the derived image is stored in the file system?
satre-2
(To:srohde)
You can write custom java class file to download representation to Local disk
Below are the few API’s which may help you to write custom java class / utility.
To Get representation for EPMDocument/Drawing
VisualizationHelper helper = new VisualizationHelper();
QueryResult qr = helper.getRepresentations(epmm);
Write custom method to file correct and default representation
Representation representation = getLatestRepresentation(qr);
Use below code to download representation/PDF to folder Local Drive.
  ContentHolder holder = ContentHelper.service.getContents(representation);
  Vector contents = ContentHelper.getContentListAll(holder);
  ApplicationData data = null;
  for (int i = 0; i < contents.size(); i++) {
  if (contents.get(i) instanceof ApplicationData) {
  data = (ApplicationData) contents.get(i);
  if (data != null && data.getFileName().endsWith(".pdf")) {
  iDownloadDocuments++;
  String dLFile = data.getFileName();
  int index = dLFile.lastIndexOf("_");
  String dLFile_trim = dLFile.substring(0,index);
  //String out_path_dir = dlLoc + "\\" +dLFile;
  String path = dlLoc + "\\" + dLFile_trim+"_"
  + epmm.getVersionIdentifier().getValue()
  + epmm.getIterationIdentifier().getValue()
  + ".pdf";
  ContentServerHelper.service.writeContentStream(
  data, path.toUpperCase());
  writelog(epmm.getCADName() + " : PDF downloaded");
  System.out.println("Download Executed.\n");
  System.out.println("File name is"+data.getFileName());
  break;
Hope this helps !!!
Shreyas
srohde
(To:satre-2)
I never wrote a java class for windchill. Haven't set up any IDE to write custom code for windchill. Would prefer a database solution if possible.
satre-2
(To:srohde)
from
where
Hope it helps !!
Shreyas
satre-2
(To:satre-2)
Also above SQL will only work if you have configured vaulting rule to store derived images in File vault not in blob.
if derived images are stored in blob then you have to write custom java class to extract all PDF's in bulk
srohde
(To:srohde)
This was what i searched for , works like a charm. Thank you very much sir . Your help was greatly appreciated.
