How to export subtypes as loadfiles?
PeterWigren
Hello!
Does anyone know if it's possible to export a subtype of WTDocument as a separate loadfile(s)?
The below loadfile will export the CADDocument type:
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
<csvExportDefinition handler="com.ptc.core.lwc.server.TypeDefinitionExporter.beginExportDefinition">
<csvtoLocation>/ptc/Windchill/temp/export/types/CAD_Document</csvtoLocation>
<csvtoFileName>CAD_Document.xml</csvtoFileName>
<csvexportDefClass>com.ptc.core.lwc.server.LWCTypeDefinition</csvexportDefClass>
<csvexportNames>com.volvo.DefaultEPMDocument</csvexportNames>
<csvmode>0</csvmode>
<csvExportAncestorTypes>true</csvExportAncestorTypes>
</csvExportDefinition>
</NmLoader>
Loading that exportfile will generate 3 xml files that can be used to load in another system to make it identical.
To export a subtype of WTDocument I have tried the following:
<NmLoader>
<csvtoLocation>/ptc/Windchill/temp/export/types/MySubDocument</csvtoLocation>
<csvtoFileName>AVP_Info.xml</csvtoFileName>
<csvexportNames>wt.doc.WTDocument|com.volvo.MySubDocument</csvexportNames>
<csvExportAncestorTypes>false</csvExportAncestorTypes>
</NmLoader>
However when loading the above code, the output file (only 1 is produced) is next to empty:
<?xml version="1.0" encoding="UTF-8"?>
<NmLoader>
<csvTypeNodeIconRoot handler="com.ptc.core.lwc.server.TypeDefinitionLoader.getIconRoot">
<csviconRoot/>
</csvTypeNodeIconRoot>
</NmLoader>
Any help or insight is appreciated!
Best regards,
Peter
Did you try extracting only sub typing using its internal name? This worked for me. You could have different files generated for each sub types.
<csvexportNames>com.volvo.MySubDocument</csvexportNames>
